Hi all,
I developed a library that i want to use to realize interactive communication between to machines running an application developed in CVI.
I thought to use a DSC custom I/O server -periodic.
I created SV to manage inputs from my application;
I created a VI that reads SV and returns data for my application;
I correctly created my periodic I/O server from this VI;
I tested it on development machine and it works.
Now I'm having troubles when i try to deploy my library on a run time/test machine.
Before I successfully used this machine to deploy library that contains shared variables only, but now i received an error that it is impossible to append an item. If i look in Variable Manager shared variable are correctly inserted in my process, but the IO server is absent.
To deploy my library i use the same executable i used successfully for my previous libs on same test machine.
I followed the steps reported in the Tutorial ID:3V762SXL "How can I distribute Periodic IO Servers to DSC Run-Time System Machines?" with no success. I tried also with the DeployLibrary.vi under DSC>Engine Control.
I'm afraid i missed to install some component, because when i copied the registration and template files i could not find folder %NI%\Shared\DSC, but which component?
I had this problem also when i had to create a OPC Client IO Server (on a runtime machine), but i solved installing OPC_IO_Server from DSC Module CD.
I attach deployment vi.
the versions i have are:
Labview 8.2.1, DSC Module 8.2.1.
Thanks and best regards.
Message Edited by Orio on
03-07-2008 04:46 AM
