Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Error with Agilent E4440A labView driver
I Have an Agilent E4440A and I want to use LabView 7.1 for instrument control. I downloaded the agpsa istrument drivers from NI site
but it does not work properly:
here is the error message:
agpsa Initialize With Options.vi<ERR>Driver Status: (Hex 0xBFFA000F) Primary Error: (Hex 0xBFFA000F) Invalid parameter.
Con you help me?
Regards
Gian Luca
Messaggio 1 di 2
5.329Visualizzazioni
Hi Gian Luca,
I think Labview 7.1 is not supported by the driver; on the download page it is specified for Labview 8.0; I downloaded it And I have seen it is composed by a project, which is a feature not implemented in LV 7.1.
If you can, I suggest you to try the driver on a newer version of Labview (8.x); if you don't have a copy, download an evaluation copy.
Lucius
Messaggio 2 di 2
5.310Visualizzazioni
