Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Errors while trying to deploy pda labview
I'm a total newbie for what concerns PDA applications so maybe I got something wrong...
I'm trying to build an example vi usign my pocketpc (2003) as a target using labview 8.0
I installed first labview 8 then embedded c++ sp4 and then pocket pc sdk 2003.
Finally I installed labview 8 pda module.
but every time I try to build a vi (even the supplied examples) I get a
" Error building executable. Unable to create file." An unknown error occured. Please contact National Instruments for more help
my destination folder is \my documents on the PDA and a local folder on my pc, and I have access to both...
I tried even build the same vi for a PDA emulator target and I get the same cryptic error message...
any idea?
Messaggio 1 di 2
4.341Visualizzazioni
Hi Democritos,
Often this kind of error appears when you are trying to deploy to the PDA target something that the PDA does not support.
I would start from this two document.
Why Do I Receive An Unknown Error When Building a LabVIEW VI For PDA?
How Can I Tell What Features for Controls and Indicators are Supported in the LabVIEW PDA Module?
Another source of the same cryptic error message can be an improper installation of all the module needed to build PDA application, the first document suggested above point in this direction too.
I would check the PDA module manual and verify the proper installation order.
LabVIEW 8.0 PDA Module Help
I hope you can dig out a solution from these documents.
Write if you need further help
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
Messaggio 2 di 2
4.334Visualizzazioni
