Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
How to input data in a database table without knowing table and column configurations in advance
I have a problem using LabVIEW for input data (manually) in a SQL database. I have about 40 tables in the database, each of them is related to a specific engine component. I need to create a user interface (maybe visualizing the table with a table control) where the users can insert data in the database table fields. Could someone give me some suggestion on how to do it?
Using the  DB tools insert data.vi I need to know in advance the column configuration of the table, but in my database each table has its own structure! So do I have to create 40 different masks, one for every different table?
Thanks in advance.
Michela
Messaggio 1 di 1
3.803Visualizzazioni
