in data 04-27-2008 08:28 AM
in data 04-30-2008 06:55 AM
Dear Montmorency,
I just would like to ask you to confirm me if your problem is to use VB6, .NET or VS C++ for accessing and using a "Labview Clipboard Object".
I can't seem to find anything regarding writing or reading directly to the LabVIEW clipboard, although the clipboard does exist. Nevertheless it is possible to read and write from the labVIEW clipboard in LabVIEW by using an Application Invoke Node for a Clipboard method.
Knowing something more about your application and how you plan to get the data into the clipboard into the first place would help out to give a better support..
Hudson | AE NIIT
