Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Limit of my NI PXI-8461/2 (my card seems to be blocked)
I use a NI PXI-8461/2 to control two Instrumentation Cluster via CAN. I need to use a lot of (30 / 50 depending by the application) of periodical nodes. My LabVIEW application, after few hours of regular operation, seems to be ok but the CAN card is blocked (no packets sent, verified with CANalyzer).
I don't know if it could be caused by a software error or a sort of hardware "overflow".
Thank You
davide
Messaggio 1 di 1
3.669Visualizzazioni
