Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Problem with a DLL for VisualBasic
    I have generated a DLL for VisualBasic using LabWindowsCVI v.7.1. The DLL work correctly on the PC where I have installed CVI and VisualBasic 6.0. The problem is when I move the DLL on the PC for the application, where I have installed only  VisualBasic 6.0:
VisualBasic is not able to see (and of course to use) the DLL !  I have copy the DLL in C:\WINDOWS\SYSTEM32 directory but VB generate an runtime error 48: impossible to find FILENAME.DLL.
I have try to use the REGSVR command, but I have the error "LoadLibrary ("FILENAME.DLL") failed. GetLastError returns 0x0000001f".
The O.S. of the two PC is WindowsXP Prof. SP2.  I attach the DLL and the VB project for test.
        ThankYou
Messaggio 1 di 2
4.981Visualizzazioni
There's got to be something not right with the DLL you generated. It is appearently not possible to register it on Windows. This is what is causing VB not to find it.
I tried to register it on my machine in 2 different places but you can see attached what the result was
AlessioD
PS: Il forum Italiano e' stato creato con lo scopo di agevolare la comunicazione in lingua italiana. Sentitevi liberi di postare in Italiano!
Messaggio 2 di 2
4.972Visualizzazioni
