Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
error transferring file to target
when i open vision assistant and i chose an colomatching pattern and set it from a sample on my computer and i click on finish NI VISION ASSISTANT show me this
 and if i set the admin password of myrio that is the same with i login on the browser panel it told me this
what should i do?
Messaggio 1 di 9
7.395Visualizzazioni
Hi Gmazzo91,
just a couple of questions:
What software did you installed on MyRio?
the vi in image is a RT vi?
It could be also an incorrect installation... but are necessary more info for debug.
Messaggio 2 di 9
7.375Visualizzazioni
hi Lamber_86 in my rio i installed after few problem the version 1.0.0f1 that should be the recovry firmware with the software that i need yes the vi in the image is a RT i dont think it depends from the installation because i reinstalled all and the problem is the same
Messaggio 3 di 9
7.372Visualizzazioni
i mean all the packages installed on myrio
Messaggio 4 di 9
7.369Visualizzazioni
ther's anything you need?
Messaggio 5 di 9
7.367Visualizzazioni
It seems that you don't have one or more component required.
Try to transform vision assistan into subvi --> right click --> Open front panel.
Try to debug and find what function return that error, disabling sequentially various part of code.
Messaggio 6 di 9
7.337Visualizzazioni
thanks for your reply i find two error that vision assistant doesnt told me the error is this
and after this he also told me this
i think the second depends from the first but i dont understand why
Messaggio 7 di 9
7.318Visualizzazioni
This is a known issue that is CARed (CAR #476578). The bug is not in the generated code. It is in the code that downloads the extra files needed by the code generated to Linux RT targets.
There is a workaround that is to install the Legacy FTP Server (deprecated) 1.3.0.
Try it out and let us know if it works.
Messaggio 8 di 9
7.288Visualizzazioni
I have this same problem. I only get the error when I try to use object tracking. I am assuming it cannot transfer the .nitf file to the myRIO. I tried installing to legacy ftp server. It still does not work. I am getting the same error as he was. Thanks!
Messaggio 9 di 9
6.335Visualizzazioni
