Forum Italiano sui Prodotti NI
annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
matlab
hello!
i want to use the mathscript node to filt the wave,i use the wavelet function,but the labview can't run this function.  how can i do?
the wavelet program in M file is
t=0:1000;
z1=sin(5*t) + cos(7*t);
xd=wden(z1,'heursure','s','one',5,'db5');
subplot(2,1,1);
plot(xd);
title('the signal');
Messaggio 1 di 2
3.551Visualizzazioni
Hey,
if you can't use Mathscript node in LV for your function,
then you have to option:
either create a dll anc call it in LV, or, for further analysis, evaluating this solution:
Custom Wavelet Analysis Using Signal Processing Toolkit in LabVIEW
http://digital.ni.com/public.nsf/allkb/11ABBF34A0D8E9BB86256E55005CA69D?OpenDocument
Hope this helps!
KIM
Messaggio 2 di 2
3.532Visualizzazioni
