G Web Development Software
24-hour time on Graph axis
I have an XY Graph that I've set up for time on the X-axis.  I want to show 24-hour time on the axis.
The way I've done that is set the X-axis formatting to "Absolute Time", and then selected the time format to be "hh:mm".  Beneath that, there's a pair of radio buttons for AM/PM or 24-hour time.  When I select 24-hour time, it looks like it uses 12-hour time without the AM/PM indicator.  I would expect, for example, that "05:00 PM" becomes "17:00".  But from what I can tell, "05:00 PM" becomes "05:00".
Am I doing something wrong?  Is there an alternate way to get 24-hour time on the axis?
Screenshots below:
Brian Powell
Stravaro, LLC
Learn more about the DSH Pragmatic Software Development Workshops.
(2,644 Views)
I meant to test this in both the IDE and the browser (Chrome, in my case) before posting, but forgot to test the browser.
I get correct results in the browser.  Here's another screenshot, with the G Web IDE on the left, and Chrome on the right.
So I suspect this is just a bug in the IDE.
Brian Powell
Stravaro, LLC
(2,640 Views)
Brian,
How did you get the correct timestamps to show up on the time axis in absolute mode?
I have waveform data that I am pushing from an RT target but the JSON in the message API will not accept a waveform type.
Steven Howell
Controls and Instrumentation Engineer
Jacobs Technologies
NASA Johnson Space Center
(2,609 Views)
Hi, Steven.  I am using the timestamp data type as my X data type.  I have nonlinear spacing of data, so I started with an array of cluster of timestamp and double.  I needed to add multiple plots, so I switched to an array of cluster of array of timestamp and array of double.  (I think I have that right.)
Brian Powell
Stravaro, LLC
(2,596 Views)
Thanks Brian,
Appreciate the help.
Steven Howell
Jacobs Technologies
(2,576 Views)
