G Web Development Software
Continous Deployment of WebVIs to Systemlink
Currently the only a way I found to add or update a WebVI on our Systemlnk Server was through manually selecting the nipkg.
Is there a way - maybe through the ni package manager feeds to automatically deploy/update a webvi application on the server?
Thanks!
(2,445 Views)
Accepted by topic author JoGra
Don't believe there is a way to do so from a package feed. There is an HTTP REST API for the Document Service and the PUT /webapps/{id}/content endpoint is used to update an existing WebVI with the id.
There isn't a LabVIEW API for the document service specifically but I was able to call the end point leveraging bits of the SystemLink Configuration VIs and the HTTP Client VIs like follows:
Milan
(2,418 Views)
Hi
I have 2 question:
  1. Is there any similar solution to update a file without changing its ID? according to this ,I think it is possible to determine the upload file id
  2. Is there any way to edit a tdms file uploaded to the systmelink server?
(2,175 Views)
