G Web Development Software
Exponential functions
I want to include an exponential function in my code, but the exponential node only seems to include Logarithm Base 10. Why is there such a limited choice of math functions in G Web? Is there any way around? Thank you for your help.
(3,698 Views)
Accepted by topic author rtowers141
Never mind. I'm building my exponential with complex trigonometric functions.
(3,685 Views)
As a future reference, another idea could be to use the JavaScript Library Interface to call existing JavaScript functions that might be useful. The JavaScript language has several Math functions that you can call with the JSLI.
The following is an example of using the JSLI to create a Node named Natural Log that will call the JavaScript global Math.log with one numeric argument and a numeric return value:
And then I can use the Natural Log node on my diagram:
Milan
(3,586 Views)
Alternatively, you can convert ln to log(10). We used it and it worked fine.
ln(x) = log(x)/log(e)
Thanks & Regards,
Irfan
(CLD)
https://haliatech.com/
(3,518 Views)
