G Web Development Software
Hyperlinks not working as per the examples
I'm trying to emulate the structure of two of the G Web examples:
  • Call SystemLink Data Services
  • Multiple Top-Level WebVIs
When I upload any of these examples to my SystemLink server, they run just fine.
Then, I build my own application and I place hyperlinks on the panel of index.gviweb and I configure them the same as I see in the examples (or so I think...). However, after uploading, when I click any of my hyperlinks, I get the message:
{"error":{"args":[],"code":-252540,"message":"Webapp content does not exist.","name":"DocumentManager.ContentNotFound"}}
Am I missing something?
(2,499 Views)
Could you post a simple project (which doesn't anything specific to your application) where you can reproduce this?
Sujay Narayana
Principal Software Engineer
(2,481 Views)
Hello Sujay,
Thank you for reaching out. Please find attached the simplest project I can think of. Again, I drag the package into the Web Applications page of my  SystemLink and I see the same message each time I click any of the hyperlinks.
Mihai
(2,445 Views)
Accepted by topic author Mihai
Thanks for the example project. In the project, the other webVIs (First.gviweb, Second.gviweb, Third.gviweb) were not marked as "Top-level VI" in the component document. Hence they were not built and included in the build output. Once I marked them as top-level and built, the hyperlinks worked fine.
Sujay Narayana
(2,436 Views)
Thank you, Sujay!
(2,425 Views)
