G Web Development Software
Sliders on touch screens.
I encountered a problem with the sliders. I'm currently trying to create a web interface that can be accessed and used primarily from my phone, but also from any other touchscreen device. The problem is that sliders do not work at all on touch interfaces. I'll share a video below demonstrating the problem. Using a cursor on the webpage there is no problem the slider works perfectly, but when I switch the dev tool to touchscreen mode (or try to open the webpage on my phone) the slider can only be dragged a few tick and then loses grip.
Is there anything I can do to make the built-in ni-slider work in touchscreen?
(1,698 Views)
Having the same problem, tried making the slider wider and transparent but that doesn't seem to work, are there more slider options like in LabVIEW? Any chance I can scroll thru data on the graph itself (http://bionichaos.com/IEEG_2.html) without a slider or using some sort of transparent controller?
(1,624 Views)
