G Web Development Software
Wind graph
Im mapping some wind parameters, and im currently displaying them like this:
Labmecepel_1-1708434019663.png]
(goes up to 360 degrees)
Is there any way to do something like this (showing direction and intensity of speed in a period of time):
(3,145 Views)
A 2D picture allows you to draw anything you want.
(Sorry, not sure if G web has that)
(3,105 Views)
Nothing in G Web directly. You'd have to integrate a 3rd party plotting library with an HTML container and JSLI. If you have a LabVIEW app running that's collecting data for the web app you could do the image drawing there and load that into the G Web app.
~ Helping pave the path to long-term living and thriving in space. ~
(3,079 Views)
You do have an intensity graph that you can use as a canvas (all axes hidden, one pixel per 2D array element), the just fill values corresponding to the various Z colors.
(3,039 Views)
Accepted by topic author Labmecepel
Here's a trivial example. Your data would need more code, of course. Easiest would be to keep the 2D array in a shift register and update elements as needed.
(3,035 Views)
Thanks for your time,
I will try to work out with this example!
(3,027 Views)
