G#
By reference vs. By value
I used Sybio GOOP for few projects and quite aware of few things in it.  Out of those experience, I'm going to give some presentation (@CLA Summit India) on my experience with GOOP and how it actually leverages the LVOOP.  Though I have used it widely, I'm not basically from computer science stream and had no good idea about OOP itself.  Now I have fair idea about OOP by going through some books.  I am looking back at GOOP now and have lot of questions on my way.
  • Why one should use by-reference over by-value.  What are the advantages of by-reference.  What can't be done with by-value which is filled by by-reference model.
    • I got to know that it gives control over construction or destruction of the objects.  I uderstand from googling that widely other languages (like C# C++ etc) use by-references model, I assumed that it's common design pattern or programming paradigm which would be advantageous.  However, I have no clear answer for this.
I have posted this question in GOOP community and I'm waiting for the response.  Meanwhile, I thought of posting it here to get some answers.
Ajay.
Ajay MV
(9,306 Views)
One simple reason - if you fork you wire in by-value based OO, you actually clone the object. You don't do this in by-reference. This is a hugh problem using by-value when you e.g. have two parallell loops and want to work on the same object in both loops. When using by-value classes you usually end up putting a queue or something like that in your class private data and then actually converting to a by-reference class even if it looks "by-value".
Mattias
(8,567 Views)
Mattias_Ericsson,
Thanks for the reply.  Is there any other vital reason when people goes for by-reference?   I always thought if I need a singleton-class, I can have the LVOOP object in an FGV or global and share it between the loops.
There is some more reply from the other thread
https://decibel.ni.com/content/message/138128#138128
-Ajay
Ajay MV
(8,567 Views)
Yes, you can easily solve it that way. In G# you can create a singleton class in which case any reference will grab the same instance.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(8,567 Views)
