G#
Deserialization as xml
Hi there;
I think there is bug in deserilization of G# class using xml. It happened when I put the attribute a cluster inside the cluster (MyTestClass2.lvclass attribute). I suspect that the function G#Object_ParseClusterXML.vi does not parse the xml correctly. I attached the code which produce the bug. Please run the G# - SerializationExample2.vi which used the MyTestClass2 class to serialize and deserialize to xml file.
Thanks.
DAKBIAS
(10,331 Views)
Please set the "as xml" button to TRUE before run, otherwise, it will save and load as binary file and return the correct value. One more thing is, try to fill all the input value in G# - SerializationExample2.vi file before run. If using xml, the value of "Account out" attribute will return null which is not correct (bug).
DAKBIAS
(7,758 Views)
Yes, you are right, there is a bug in XML serialization if you put two clusters next to each other. I will have a look at it and come back with a fix. I do agree that it is probably the G#Object_ParseClusterXML.vi that has the annoying bug.
Thanks for reporting this,
Mattias
(7,759 Views)
I just made a fix in the latest release. I actually removed the support for matching attributes. It was the thing causing the bug and it was a bit too complex to find a simple solution. This is more safe. Please download latest release 1.4.5 from: http://www.addq.se/gsharp.
Mattias
(7,759 Views)
Thanks fot he fix. It works now Thank you very much
DAKBIAS
(7,759 Views)
Hi
I guess 1.4.5 refers to the framework ?
My Version information says
G# Framework 1.4.4
G# Version 1.5.0
Gabi
Please see also my other question about de-serialisation.
7.1 -- 2013
CLA
(7,759 Views)
Hi, yes 1.4.5 is the entire framework, This is the "offical" version. G# 1.5.0 is the root G# class version that all classes inherits from.
(7,759 Views)
