G#
Dynamic terminals must be of same class as owner of VI
I have experienced the following error:
- I create a new class with the G# 's class creator utility (My Comuter -> New -> G#Class).
- create a new method using the G# IDE. With the following settings:
Method template: Standard
Type: Normal Method
Dynamic Dispatch: TRUE
Scope: Public
The created method is broken. The error description is the following:
LabVIEW Object 'class data in': Dynamic terminals must be of same class as owner of VI
LabVIEW Object 'class data out': Dynamic terminals must be of same class as owner of VI
I use LabVIEW 2011 32 bit, Windows 7 Professional 64 bit.
What may be the problem? Can anyone help me?
(8,524 Views)
Seems very strange. Never heard about this before and I sounds like you are trying to do the most basic thing of all, just creating a method.
Just a couple of questions:
1) Which G# version are you using?
2) Have you tried to reinstall G# IDE?
3) Are you working on a local disk?
4) Can you repeat it? This is the same for all class names and method names?
Could you also please upload the class so I can have a look at it? You can also mail it to support@addq.se.
Mattias
(6,982 Views)
I have tried it on two different PCs and both gave the error.
1.G# Framework version on this PC : 1.4.2 G# version 1.3.6
2. No, I didn#t try to reinstall it, maybe will.
3. yes, local disk.
4. Yes, repeatable. I guess you can also repeat it if you have LV 2011.
I just sent you the code.
(6,982 Views)
I got the code. You actually found a bug there. You are using LabVIEW native classes and there was a bug when using this template. This bug was actually introduced in version 1.2.5, when fixing another bug. There aren't many users of G# that uses the native class template, I guess that's why we haven't seen it or got a report of it before.
However, it was easy to fix and I attach a bugfixed VI. Please replace the attached VI at the following path (and then restart LabVIEW):
C:\Program Files (x86)\National Instruments\LabVIEW 2011\resource\Framework\Providers\AddQ\G#IDE\support\ScriptingLib
It will be included in the next G# Framework release. Really sorry for this! Thanks for reporting this bug to us.
/Mattias
(6,980 Views)
Hi Mattias,
Thank you for the real fast answer and solution!
I just tried the fix and it works fine, Thanks again!
(6,980 Views)
Hi Matthias,
I just have used the G# 1.4.3, and the fix doesn't seem to be in it.
I have the same error message again.
(6,980 Views)
No, it is in version 1.4.4. We've included a few more fixes as well that we been verified. I released this new version and please download from:
http://www.addq.se/gsharp
The page still indicates that current version is 1.4.3, but it is 1.4.4 if you download (click readme link). Our web managers is a bit slow updating the page.
Mattias
(6,980 Views)
