G#
G# GenericCreate.Vi gives error of 400043, but NOT when you call the G#Object_create.vi (specific)
Hello everyone,
I am having problem implementing Dependency injection with G# generic Create function. I have ObjA and ObjB. A is a parent class of B. I create objC and objD (all objs under G# framework, not related to previous objects, except through G# ofcourse)) and i encapsulate C & D in ObjA and ObjB. So for example i take objA, when I put objC_create.vi and objD_create.vi inside ObjA_create.vi, and run the G# generic Create to call ObjA, i get this error of 4000043. However, when i run the ObjA_create.vi itself, without using the G# generic Create, It runs completely fine.
Here are the two cases.
[case 1]: Use G# Generic Create: Provided Error 400043
[case2] Use ObjA_create.vi: works with no errors.
[NOTE] I noticed the error only started to happen when I started to add in ObjC and ObjD_create.vi inside ObjA_create.vi. Once i remove objC_create.vi and objD_create.vi, and run ObjA_create.vi,  i don't have any error.....
I would really like to use the dependency injection method so that i can switch between objA and objB within my MAIN program. It's hard to share example code for this situation so i hope these snippets can explain my situation. NEED HELP! Thanks in advance!
[ps: I added a labview project, "DependencyInjection.zip", to demonstrate what I just explained].
(2,555 Views)
Accepted by topic author villanul
You need to run G#Object.lvclass:G#Object_StartExternalCreateProcess.vi at the start of your application for case 1 to work.
There is a hint in the error message "Does a process really reply to the "External create object" event?", but I think the message could point out more specifically to check if the external create process VI is started.
Certified LabVIEW Architect
(2,512 Views)
Thank you very much! This indeed fixed the problem. It would be nice if the examples of G# included this implementation as an example, (or maybe i didnt see it). I traced the event loop structure that output this error, but i was unsure how to start an external process.
cheers,
(2,500 Views)
cheers,
There is a 'short' named example: G# - DependencyInjectionUsingExternalCreateProcessWithDefaultConstructor.vi
Qestit Systems
Certified-LabVIEW-Developer
(2,493 Views)
