G#
G# Help file sometimes get blocked - solution
Hi all,
There has occationally occurred that the G# Help file get blocked by Windows for some users. When launching the Gsharp.chm help file, the right frame shows a message "Navigation to the webpage was canceled". The cause of this is that Windows security blocks the chm-file, there might also be a warning dialog before.
To solve this please make the following:
1) Locate the file in the Windows Explorer:
C:\Program Files\National Instruments\LabVIEW 2009\help\_AddQ\Gsharp.chm
2) Right-click on the Gsharp.chm and select "Properties".
3) Click on the button "Unblock" on the "General Tab".
4) Done. It should now open.
This seems to be a quite common problems with chm-file. I will get back when there might be a more permanent solution.
Mattias
Message 1 of 1
(11,894 Views)
