G#
G# StarUML 1.2.1 installation problem
I am using Windows 7 (64bit) and Labview 2013 (32bit) and I am trying to install G# StarUML.
When i try to run the G#StarUMLPluginInstaller.vi i get the warning ”.NET assembly changed" and this prevents me from completing the installation. A screenshot of the error message is shown here:
I have set the system decimal sign to '.' and I have also tried to start labview as administrator but that does not help. Does anyone know how to solve this problem?
Rui
Message 1 of 10
(15,922 Views)
Hi Rui,
LV2013 changed to .NET 4 as standard, that's the message you're getting. I'm uploading G# StarUML changed to .NET 4. to the document section, see link.
https://decibel.ni.com/content/docs/DOC-32200
Regards
/Yamaeda
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 10
(11,978 Views)
Hi Yamaeda,
Thanks for your quick reply. Now I dont get any .NET error anymore. However, it still dosen't work. I get the error
even if I follow the instructions.
I also discovered that starUML crashes on starup with the message:
Problem signature:
  Problem Event Name:          APPCRASH
  Application Name:          StarUML.exe
  Application Version:          5.0.2.1570
  Application Timestamp:          2a425e19
  Fault Module Name:          KERNELBASE.dll
  Fault Module Version:          6.1.7601.17965
  Fault Module Timestamp:          506dbe50
  Exception Code:          0eedfade
  Exception Offset:          0000c41f
  OS Version:          6.1.7601.2.1.0.256.48
  Locale ID:          1053
  Additional Information 1:          ad85
  Additional Information 2:          ad855802b65f7d79d26fcdaef6dcca93
  Additional Information 3:          83ec
  Additional Information 4:          83ecd427dfbaa6aeff7f4d4aa075604d
Could that be the cause of the problem? How do I solve it?
Rui
Message 3 of 10
(11,978 Views)
I found a solution to the starUML crash problem here:
http://sourceforge.net/p/staruml/discussion/510442/thread/9fe12cac/
So now starUML works, however, the problem with installation of the G# plugin remains
Message 4 of 10
(11,978 Views)
I also got that same error message in LV2013, but by opening LV with "Run as administrator" and then opening the installer.vi from LV (if i double click the file i'll spawn another LV with ordinary rights) it worked.
Tell us if that works.
regards
/Yamaeda
Qestit Systems
Message 5 of 10
(11,978 Views)
Thanks for your help Yamaeda but it still does not work for me...:(
I tried doing what you suggested before, right clicking LV, selecting "Run as administrator" select the root user and the open the "G#StarUMLPluginInstaller.vi" from that instance of LV. But I still get the error message. I also tried to switch account and log in as root but that didn't work either.
Rui
Message 6 of 10
(11,978 Views)
One thing you can try is adding the Installer.vi to an empty project as this'll allow recompilation and stuff, and run it through that. I cant really reproduce the issue so it's hard to give better advice.
/Y
Qestit Systems
Message 7 of 10
(11,978 Views)
Hm, that didn't work just to make sure, I am running win7 64 bit and LV2013 32 bit (as root) and I have installed StarUML and changed system decimal symbol to '.'. Is there anything else that shall be setup or installed? Or is there any other way to install the G#StarUML plugin (i.e. copy files manually)
Rui
Message 8 of 10
(11,978 Views)
Hello Rui!
I have also been trying to reproduce the error that you have encountered but have had no luck.
You are asking if you could manually copy the files into the right folders on your system. It should work as this is what the installer does.
In your downloaded G# StarUML Plug-in 1.2.x.zip there is a folder called "files". Inside it you will find:
1. Labview
2. StarUML
Copy the contents of Labview (1) into <YourSystemDisk>\<Labview2013Folder>\
Then copy the contents of StarUML (2) into <YourSystemDisk>\<StarUMLFolder>\
When you have done this you shold mass compile <YourSystemDisk>\<Labview2013Folder>\resource\Framework\Providers\AddQ\G#UML
I hope this will solve your problem. We will continue to try to reproduce this bug and eventually, solve it. If you get to the bottom of the problem, please let us know so that we can further improve the G# StarUML Plug-in!
Sincerely,
Andreas
Message 9 of 10
(11,978 Views)
Thanks for your support.
I tried the "manual install" but I don't think it worked. The copying and mass compile went fine but I still can't see the G# option in the tools menu in StarUML. (However, the G# approach is available at startup so it seems like something worked). Any idea what could cause this problem?
Rui
Message 10 of 10
(11,978 Views)
