G#
Need easy Tutorials to Understand G#
I am sorry to ask more questions but have you implemented the hierarical type of inheritance how many sub classes can inherit from one base class ???? or should I implement implement interfacing like in java and like  how can we use xcontrols with G# plz help plz reply. waiting for reply
Bharath
Thanks & Regards,
Bharath Kumar
GCentral
Message 11 of 16
(3,749 Views)
1. inheritance: G# classes inheritance uses LabVIEWs inheritance. There is no difference there and no limitations I know of.
2. Interface: In G# it is possible to use interfaces. A feature I use in the current project and it works well.
3. Xcontrols: I use xcontrols in the current project and have not seen any issue. However, I advise you read all documentation and caveats for xcontrols.
Certified LabVIEW Architect
Message 12 of 16
(3,749 Views)
How to use the class attributes in the protected. I try to access the attributes in create method but can only use the Objectattributes Am i worng?. I think the class attributes if defined it will be constant throughout the class. I try to put a refnum as constant for the class .Is it right ?
Bharath
Thanks & Regards,
Bharath Kumar
GCentral
Message 13 of 16
(3,749 Views)
I have to say I don't really understand what you are asking. Perhaps you can share a code example in order to make it easier to help. But I can say from my own experience that I never use class attributes. Class attributes tend to hide implementation and there is always a design pattern that will solve the problem better.
If you need to learn more about design patterns, I suggest you start with Gang of Four: http://books.google.se/books/about/Design_Patterns.html?id=IvujngEACAAJ&redir_esc=y
//Thomas
Message 14 of 16
(3,749 Views)
Hi Mattias,
To inherit a base class should i select the base class instead of G# object when creating a class?
Thanks & Regards,
Bharath Kumar
GCentral
Message 15 of 16
(3,749 Views)
Yes.
Mattias
Message 16 of 16
(3,749 Views)
