G#
Plug In classes with G#
Hello
I'm new with G# I find it is very useful and easy
Is it possible to create Plug in classes?
Because I always need the "Create Method"
(7,557 Views)
Hi diego_fro
Not exactly sure what you mean by plugin classes.
We use a design pattern with the g# object create method that is called dependency injection.
It,s purpose is to create a more "loose" coupling in designs and with that we can do something we call a plugin structure for classes.
Pls have a look at the examples for g# regarding dependency injection and see if you find it useful, it's available in the g# examples in your normal examples folder
//Patrik
(6,658 Views)
Hi Patrik
thank you for the answer
the dependency injection is what I need !
best regards
Diego
(6,658 Views)
Nice, hope it will be usefull.
Please remember that classes using dependency injection is not "loaded" in an instance as you normally find it when developing. Its loaded in runtime....
//Patrik
(6,658 Views)
