G#
might be a bug about G# interface with shared variable(PSP) deployment ?
          I'm using G# interface to implemented a Observers Design Pattern. In my LabVIEW project I used a shared variable. Each time when I run Notify vi (a function in Observer Pattern) It force the project to deploy the variable again. So when I invoke Notify continuously I got a endless prompt of the deployment window.
           Who can help me? Thanks!
(6,531 Views)
Would it be possible to post a small example?
/Mattias
(5,439 Views)
Thank you for your reply!
            I tried to delete three files( project.aliases/project.lvlps/project.lvproj ) and build a new project. Then added the original files and classes of the previous one to the new project. Then the problem sloved!
Thanks!
(5,439 Views)
