GDS(Goop Development Suite)
Design Patterns
Share and discuss your commonly used design patterns.
(11,879 Views)
Hi
I've added two design patterns implementations based on the book: "Head First Design Patterns", using GOOP4.
This is a book I can recommend.
Cheers,
Mike
Oops, I did see that the project is referring to a missing class, just ignore that.
Also, I just saw that I use my own dialog VI, in the Door,Fan and Light classes.
Replace the VI: LcDialog_AutoSizeDialog.vi, with a single One utton Dialog.
The VIs you need to update are:
GarageDoor_class\Open.vi  \Close.vi
Light_class\On.vi \Off.vi
CeilingFan_class\SetSpeed.vi
Message was edited by: MikaelH
(7,878 Views)
...and it looks like now I'll need to install OpenG.
I'm hoping not to have to load my code up with too many dependencies as it tends to frighten people away from using it.  Chasing versions is always a nightmare with all these add-ins...
(7,878 Views)
