GDS(Goop Development Suite)
GDS Error when creating property node method on EndovoGOOP400 Class
After creating a new GOOP Class using the class provider EndovoGOOP400 I tried to add a method to the class.
Adding a method of the type property node resulted in a GDS error.
The GDS Error Log reported an error 7 (File not found).
After some debugging it appeared that there is a problem in the file
C:\Program Files\National Instruments\LabVIEW 2013\resource\Framework\Providers\Symbio_GDS\ClassProviders\Provider_EndevoGOOP400\Templates\G4BaseTemplate_Simple_6x8x6\methods\methods.ini
It contains :
[PropertyNodeMethods]
Read Property=G4BaseTemplate_Simple_6x8x6__ReadProperty.vi
Write Property=G4BaseTemplate_Simple_6x8x6__WriteProperty.vi
While it should be :
Read Property=G4BaseTemplate_Simple_6x8x6_ReadProperty.vi
Write Property=G4BaseTemplate_Simple_6x8x6_WriteProperty.vi
So without the double underscore at the end.
Changing this to a single underscore solved the problem.
Hopefully this will be fixed in a next version.
Kind regards,
Stefan
Message 1 of 8
(11,467 Views)
Thanks for findign that Stefan.
Even OpenGDS still have that problem. I'll update it and release a new version.
Cheers,
Mike
Message 2 of 8
(9,622 Views)
Is this problem solved? I am having the same issue.
Btw thanks to Stefan his solution works. I just noticed that his message contains the fix
C:\Program Files\National Instruments\LabVIEW 2013\resource\Framework\Providers\Symbio_GDS\ClassProviders\Provider_EndevoGOOP 400\Templates\G4BaseTemplate_Simple_6x8x6\methods\methods.ini
It contains :
Kind regards,
Stefan
Message 3 of 8
(9,622 Views)
Yes it's fxed in the latest openGDS version.
What version are you running?
Message 4 of 8
(9,622 Views)
It looks like you're not runing OpenGDS?
Uninstall the Symbio_GDS, and use the latest OpenGDS version.
http://opengds.github.io/
Message 5 of 8
(9,622 Views)
I have installed it from here;
http://www.ni.com/gate/gb/GB_EVALTLKTGOOP/US
When i check it from "Product information and Uninstal..."; verson 4.8 (R4H)
1.Is it sufficient to uninstall GOOP suite from this "Product information and Uninstall..." page?
2.Does the version at github cause any conflict with my ongoing project?
3.Are there new features?
Thanks for your kind efforts...
Message 6 of 8
(9,622 Views)
Yes, you can use that way to uninstall it.
There will not be any conflicts, the software is based on the same code base, but with lots of improvements and new features.
  1. E.g.
- Rename VI(s) option. It can rename all dynamic VIs in one go.
- Create LV Code from text based Java or c# code
- (if you use the latest version: Untested), you get a 100times improvement in UML class diagram analysis speed.
Message 7 of 8
(9,622 Views)
Thanks for help. I installed the new version and as you said the problem is fixed. Let me comprehend the tool first. Then I can install and test the beta version.
Message 8 of 8
(9,622 Views)
