GDS(Goop Development Suite)
GDS Installer for VIPM LV2015
You are right, the tool just helps you auto create LV code. It should be enough to verify that the created code works and is up to your standard. It is the same thing as you would have coded it yourself.
Message 11 of 16
(3,029 Views)
Do you have any information on when the NI GOOP Development Suite for LV2015 will be released?
Jacques Scheller
Staff Applications Engineer, NI Germany
Certified LabVIEW Developer, Certified TestStand Developer
Message 12 of 16
(3,029 Views)
Is this installer (GOOP for LV2015) anytime up between these days?
Ajay MV
Message 13 of 16
(3,029 Views)
Just an update on this.  You can find the latest one for 2015 at VIPM.  I used 1.81.81 version.
Ajay MV
Message 14 of 16
(3,029 Views)
I tried to install GOOP from VIPM and it crashed.
The installation is on a CENTOS 7 machine. I did this intallation before in a windows machine and it works.
The error windows shows this information
Main Package Name: NI GOOP Development Suite v1.1.81.81
Package Name with Error: NI GOOP Development Suite v1.1.81.81
Error Message: VIPM could not install the package NI_GDS_2015-1.1.81.81 .
Error Code: 15
Error Source: (File "File Group 0/help\Open_GDS_Help.vi" not found in package) 32C71AD65E1335EBB623E2B7C7B2265F in D92B731E6551FD9D1711DD6D8FA6B2AA->OGPM Class.lvlib:3D0925F23551ED2669636E9F80B8B8D8->OGPM Class.lvlib:BB5E8E0719BF4ECCBF039A06C252CDAD->3E0871A7D46444611BE8A4134C158E2B->VIPM Main Window.vi
Can somebdody help me?
Thank you.
Message 15 of 16
(3,029 Views)
If VIPM can't handle it, use the manual installer VI from the OpenGDS version, that always works.
http://opengds.github.io/
Message 16 of 16
(3,029 Views)
