GDS(Goop Development Suite)
GDSError_ReportError.vi
Hi
Every time i close debugger tool i have message "Please save GDSError_ReportError.vi" but like is in read only i can't.
To solve this, I have modify to read-write this file property. It seem than lots (all ?) Goop files are read only. I'm not sure than it's good if we want recompile them ?
LV2018 -GOOP4
Eric
(3,645 Views)
Did you install it using VIPM or did you use the Installer_*.vi?
(3,595 Views)
Last version of VIPM. After looking in VIPM i see than i have Open GDS and NI-GOOP installed. I decide to remove all and reinstall only OpenGDS using VIPM. Now if i take look in Open_GDS, i see than all vi's are in read only like previously.
Is-it better to install it through "Installer_.Vi" ?
(3,571 Views)
I always use that installation method because it's faster, but if VIPM has an east uninstall feature. OpenGDS has a build in uninstaller in the About dialog.
(3,556 Views)
