GDS(Goop Development Suite)
Idea: Flat Folder Structure
Idea: Flat Folder Structure - Implemented and Closed
Message 1 of 13
(13,266 Views)
Make it possible to generate a flat file structure for classes in GOOP4 (no Private,Protected or Util folders) but keep that structure in the lvclass. This vill make it simpler to handle in SVN subversion.
Message 2 of 13
(7,158 Views)
Regarding a flat directory structure
How and where should the user be able to configure it?
Message 3 of 13
(7,158 Views)
Tools->GOOP->Class Provider Options... Configure class provider
could be a good place.
Message 4 of 13
(7,158 Views)
+1 for this idea!
Message 5 of 13
(7,158 Views)
Something like this:
Should I also present this option in the Create Class Dialog as well?
When I inherit from a class should I use its preferences or use the default preferences?
Message 6 of 13
(7,158 Views)
I see no need to present the option in the Create Class Dialog.. Either one or the other will be ones preferred way of working. Nothing to gain in using both schemes together.
For inheriting it should probably use the default preference, but I could think of use cases where one would like to have the option to override that and use the same scheme as the parent class.
Message 7 of 13
(7,158 Views)
Yes that will do. I see no need to mix the two, since the primary reason (for me any way) it's to simplify the use of Subversion when you have to change the access scope of a vi.
If the file structure is not flat you have to move the vi to a other folder when the access scope change (not to make a mess) and that is messy in Subversion.
Message 8 of 13
(7,158 Views)
So what should I call the option in details?
All text and help are defined in the language files, so this control will have a section like this:
[_FlatFolderStructure]
description=This is the option that turns flat folder structure ON for the GOOP4 class provider
en=Use flat folder structure for new classes
[_FlatFolderStructure_Tip]
en=Turn this option ON to have all new classes using a flat folder structure
[_FlatFolderStructure_Help]
en= Turn this option ON to have all new classes using a flat folder structure.\0AThis will not make the physical private and protected folders on disk, but still create the virtual folders. The physical and virtual utils-folder will still be created.
BTW, if someone would like to translate GDS to other langauges, feel free to add a key for that langauge, e.g.
sv=Swedish
gm=German
nl=Dutch; Flemish
The files are located here:
LabVIEW 2010\resource\Framework\Providers\Endevo\LanguageFiles
Cheers,
Mikael
//Mikael
Message 9 of 13
(7,158 Views)
Guys
I've just implemented this, but...
The only change I got was that the private folder wasn't created.
The protected folder is preferable created to place the ObjectAttributes.ctl in.
Don’t you agree?
Then when you create methods, you just have to make sure you only use the Visibility and not the Method Location option in the Create Method dialog.
Do I need to handle the Flat folder structure in any other action?
I’m uploading this build soon, (Q2K)
Cheers,
Mikael
Message 10 of 13
(7,158 Views)
