GDS(Goop Development Suite)
OpenGDS Help Documentation
For the LV2020 version I think it’s time to update the help in the OpenGDS tool.
What help format would you like to have?
I guess HTML format would be the best.
Accessing help files with your own browser using the file:/// protocol, works fine, but most help file formats are using iframes and that’s blocked on some browsers (i.e. Firefox).
So what should we do?
I was thinking of using HelpNDoc free version for the help file but the format they use is using iframes that isn’t working on all browsers.
I know that JKI’s VIMP is using local help files with the file:/// protocol and that format works.
The easiest is to upload all to the cloud and point the help to e.g.: http://opengds.github.io/help/OpenGDS%20Help.html
And one more question…who have time to help out?
Cheers,
Mike
Message 1 of 8
(7,894 Views)
Mikael:
Check out this review:
https://userguiding.com/blog/help-authoring-tools/
Message 2 of 8
(7,774 Views)
Currently I would like to have a more detailed help file. I would like to contribute iteratively to the help file. Hosting a version on GitHub seems reasonable. That would allow me to contribute a line or two.
Like you sain MikaelH the current help file using iFrames is blocked by some browsers so navigating through the help file is difficult at the moment.
Message 3 of 8
(7,393 Views)
Anyone wants to help out?
Here is the current content:
and can be cloned here: (under the help folder)
https://github.com/opengds/opengds.github.io.git
I can give you direct access to the repo just let me know.
Message 4 of 8
(7,276 Views)
Hi MakaelH, when you normally update the helpfiles, do you use normal text editor or a special editor? Is it ok if I write some help files in plain text or Markdown and convert it later on? Cause it feels cumbersome to edit html files directly.
Message 5 of 8
(6,749 Views)
We used HelpNDoc when writing the first version of the help file.
Message 6 of 8
(6,740 Views)
I see that HelpNDoc is free for personal/non-commercial use, so we could use that? I'll give it a try.
Message 7 of 8
(6,715 Views)
In the past, I did add the HelpNDoc-Project (*.hnd) in this folder:OpenGDS/Open_GDS_Tools/HelpFiles
Message 8 of 8
(6,697 Views)
