GDS(Goop Development Suite)
Reference leeks in singelton classes
I have a question about reference leaks in singelton classes.
If I have just one class it is obviously that I get a reference leak because one reference to the queue is not closed.
If I have a subclass it get more tricky. Is there a way to close al references in the end so I don’t get the leeks?trace.png
(6,947 Views)
Are you using NI GDS or OpenGDS, and what version?
I've added a way of fixing the reference leak in the later version of OpenGDS.
In the CleanUp VI for a singleton, you can now get the name of the Queue, but you need to destroy/release it yourself.
(6,742 Views)
Thanks for your answer.
It was the type of solution i was looking for.
I am using GDS_R4H_2013_64.
(6,742 Views)
