GDS(Goop Development Suite)
Separate compiled code from source file when creating new method
Hello!
I recently started using the GOOP toolkit(from NI's site and recompiled for labview 2014) and I must say i love how it simplifies a lot of things and automates boring things.
I have noticed that even though the global parameter (in the project and global, in tools-->options-->environment-->Separate compiled code from new files) for complied code is set when creating a new method in a class the new method .vi will not be created with this option set. I dont know if this is intentional, a bug or just not implmented. It would in either case be a nice thing to have especially if you use subversion for revision handling, otherwise do you always have to open the project and manually mark all the files each time you create a new method!
/Best regards Marcus
(5,981 Views)
It's not implemented.
I'll fix that in the next release of OpenGDS, this version will hopyfully be merged back into NI's version.
(5,279 Views)
BTW, This is implemenetd in the latest version of OpenGDS:
http://opengds.github.io/
Use the untested version: 1.0.37  (Most of the features are tested 🙂
(5,279 Views)
