GDS(Goop Development Suite)
UML tool - Class Diagram Compatibility
Hi everyone, I have a problem with Class Diagram compatibility. I created a Class Diagram in Open Goop 1.2.47. Then I upgraded Open Goop to version 1.2.59. Class Diagram could not be loaded. Although the Class Diagram can be loaded via export and import xmi, but it is not usable because it does not contain links. Is there a way to load a class diagram into a new version of goop?
(5,456 Views)
Sorry, I must have made it non compatible.
Can you send me the 1.2.47 uml file so I can fix it.
BTW I found a bug in version .59 in the GOOP4 Singleton class templates that is fixed in version .60
Please upgrade to that version.
Regarding the uml file format, I would love to go to json format...maybe someone likes to help out? 🙂
(5,385 Views)
Hi Mikael,
I'm sending the class diagram. Can I help you with this issue?
Pavel
(5,374 Views)
Accepted by topic author Pavel.Zdarek
Here you go.
Try the attached file in the latest version.
Looks like a great design.
//Mike
(5,355 Views)
Hi Mike,
thanks a lot, it works!
Pavel
(5,348 Views)
