GDS(Goop Development Suite)
We have released GOOP Development Suite v4.1
We have relesed GOOP Development Suite v4.1.
Most important features are:
- support for RT
- GOOP3 to GOOP4 conversion
- A new design pattern: Active object supporting dynamic events.
About design pattern. To keep generated code to a minimum only basic functionality is added by default into the GOOP 4 class. As a complement we introduced the "Add Design Pattern" feature which can be used to add extra features to the class, for example: persistent, class attributes and active object.
As usual the tool adds the same features, create class/UML code generation/etc, for native LabVIEW classes aswell as the by-reference based templates.
GOOP4 Class template version is updated so run the ClassTemplateUpdate feature to update existing code.
Download installer and read more: www.symbio.com/goop
One month free trial included, there is also the free Community Edition.
Contact goop@symbio.com for questions.
GOOP 3 vs. GOOP 4. For new projs we recommend GOOP 4. It is built using the DVR, it will perform better and we have kept the generated extra code to a minimum.
Jan Klasson and Mike Holmström
Symbio, former Endevo
Message 1 of 1
(4,958 Views)
