GDS(Goop Development Suite)
generate code from uml interface
Hello
I can not generate a code from a UML interface, i have a warning message.
Should I use an abstract class with inheritance?
(6,073 Views)
What warnings message to you get?
Make sure you have a Project Opened (and make sure it's saved).
You question: Should I use an abstract class with inheritance? , no you don't need to specify an ABSTRACT stereotype of the class, that is just for documentation purpose.
(5,178 Views)
I would like to use the strategy pattern with interface implementation,
but the interface class doesn't appear in the code.
(5,178 Views)
Since Interface don't exists in LV natively yet, it won't create those.
I do have an Interface class type, but it requires Interface through aggregation.
In your case try normal inheritance.
//Mike
(5,178 Views)
