GDS(Goop Development Suite)
"Rename class..." tool throws error on .vit members
When I use the "rename class..." tool on a class that contains a .vit member, the tool throws an error and the new class can't find the .vit file on disk (even though it was properly moved). I don't know where bug reports go or who's even working on GOOP these days, so I'm putting this here.
(6,602 Views)
I'll look into it...but why are you using vit-files, I've never needed those for the last 10 years
(5,631 Views)
Right-click-->"New from template" is a great way to add methods to a complex object. I'm surprised you don't put that feature to heavier use, given how much OOP you write.
(5,631 Views)
Right click on what?
I alwasy use the OpenGDS GOOP->Add Method feature.
(5,631 Views)
