GPU Computing
Labview GPU under Linux
Hello, I wonder if it's possible to use the GPU together with Labview under a Linux operating system?
(8,459 Views)
Currently the module uses binaries which are specific to 32-bit Windows. There's no technical reason why Linux is not supported - just resources and time.
(6,001 Views)
Here's to hoping that the resources and time become available for a Linux implementation soon!!  It would be very advantageous for my work...
Bill
(6,001 Views)
NI is continue to research GPU support in our products. With regards to Linux, I have a few questions:
  1. What kind of processing (algorithms, math ops, data management) are you needing?
  2. Will your research require a 64-bit OS?
What might be more helpful is if you post any information you can regarding your research in this thread:
https://decibel.ni.com/content/thread/8632
(6,001 Views)
