GPU Computing
Problem using xGEMM (General Matrix-Matrix Product)
I've arrived at a dead-end.
I'm trying to execute matrix multiplication with the GPU.
(see attached VI)
For comparison I did the same matrix multiplication with regular matrix operation (gemm BLAS 3)
which works fine with the same matrices.
I don't get an error I just get all zeros in the output
I checked the heat transfer demo using the same GPU function and it seems to be running ok.
so by now I have no idea what I'm doing wrong.
I'd really appreciate any helpful help.
Yoni.
(7,453 Views)
Found a solution at http://forums.ni.com/t5/LabVIEW/CUDA-Matrix-Multiplication-Fails/m-p/3262686/highlight/false#M951836
turns out its a labview 32bit/Windows 64bit compatibility issue.
(7,244 Views)
