General
roboRIO 2.0 CAD File?
Is there a 3D model of the roboRIO 2.0 available for download? I downloaded one from AndyMark, however there are many surface errors once uploading into SOLIDWORKS.
(222 Views)
The official 3D model provided by NI is the one on the AndyMark site: NI roboRIO 2.0 - AndyMark
I also find others in GrabCAD that may work for you: GrabCAD - roborio
roboRIO 1.0 models may work for your use case, as well, since the changes between 1 and 2 are quite minimal - mainly on the USB ports section.
Cheers,
(185 Views)
