Hardware Developers Community - NI sbRIO & SOM
MEM usage in FPGA 2014
I am looking at the 'Mem' data method which appears to be new to FPGA 2014. As there are no examples, I need help with some errors then trying to read the mem on the RT side.
I've started with the "sbRIO-9651 Read On-Board Temperatures" project and added a "U8 Mem" which I would like to pass a value from the FPGA side and Read on the RT side.
I've create a Mem that is U8 data type; Block Memory;
This code throws a "Can't find..." error on the RT side.
The FPGA Side of the code.
The RT Side of the CODE
I  get the following error when I attempt to run the RT VI:
Deploying nirvimemoryEmulationManagerCache.vinirvimemoryEmulationManagerCache.vi loaded with errors on the target and was closed.
LabVIEW:  (Hex 0x627) The function name for the LabVIEW:FpgaSdkMemoryEmulationWriteAddress:C           node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
LabVIEW:  (Hex 0x627) The function name for the LabVIEW:FpgaSdkMemoryEmulationReadAddress:C           node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
I am not sure how or why the compiler can't 'find' the code....
(6,994 Views)
Hi Jack,
The Memory Item should only be available to exclusively to LabVIEW FPGA. If you want access to the Memory Item from LabVIEW RT you must either pipe the data through a DMA FIFO or through front-panel I/O.
When is concerning here is that you were able to place the Memory item on a LabVIEW RT VI and it not break the run arrow.
I will file a CAR on the not breaking the run arrow when an unsupported item is placed on the RT diagram, but you will need to use the DMA FIFOs or FPGA front-panel I/O to indirectly interface with the FPGA Memory for LabVIEW RT.
- Tanner
Tannerite
(6,080 Views)
Tanner,
Thanks...
(6,080 Views)
Tanner,
I can also do this... Drag a FIFO from the Project FIFO tree onto an RT vi diagram and NOT get a broken arrow. Please detail this behavior in the CAR also.
Regards
Jack Hamilton
PS: If it's not been said, I deeply appreciate yours and Spex's quick response and support!.
(6,080 Views)
Jack,
Yeah, I will try other FPGA-specific items and document the CAR to the LabVIEW FPGA software team. I will post the CAR number shortly.
- Tanner
Tannerite
(6,080 Views)
Hi Jack,
Pretty much all of the FPGA-specific elements that only show up beneath the FPGA Target in the LabVIEW Project do not break the run arrow when drag-and-dropped to a non-LabVIEW FPGA block diagram. I have filed a CAR, 524309 to the LabVIEW FPGA team to address.
Thanks for finding this inconsistency and I apologize for the inconvenience and time this has caused.
- Tanner
Tannerite
(6,080 Views)
