Hardware Developers Community - NI sbRIO & SOM
UDP size limitations on sbRIO(e.g. 9607)/SOM
since I doesn't have a test system at hand and the NI sales guy seemed to be a little confused with the different meanings of "packet" in the OSI model (UDP <-> IP <-> Ethernet(frame))...
Is there a limitiation when sending via UDP (one call to "UDP write") special to the sbRIO/SOM HW/SW?
My goal is sending about 15000 bytes of payload in a single UDP packet.
Should this be possible?
Thanks and greetings from Munich,
Götz
(5,016 Views)
15,000 is well below the approximate 65K limit to packet size for UDP.  Should work.
http://www.ni.com/tutorial/4950/en/
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(4,993 Views)
Thanks for your estimation.
(4,966 Views)
