Hardware Developers Community - NI sbRIO & SOM
Windows IOT
is there any idea to have Windows IOT On Zynq based platform? it would be usefull to have access to the microsoft iot ecosytem with NI hardware. Windows IOT support some arm based devices.
Regards
(6,185 Views)
I assume with all the emulation to get Windows running on zynq you'd loose quite a bit of cpu efficiency. Are you looking for an embedded windows single board computer that has an FPGA?
Kyle Hartley
Senior Embedded Software Engineer
(6,124 Views)
Windows 10 iot core now can supports also a simple processor like arduino.
I'm interested in the use of ni zynq board with also the opportunity in the use microsoft software tools
Br
Lm
(6,117 Views)
