Hidden Gems in vi.lib
Dynamic Position VIs uses VI scripting?
Hi Guys,
Does the Front Panel -> Dynamic Position VIs use VI scripting? Can these be used in EXE mode?
Karthik
Using LabVIEW since 2012. Certified LabVIEW & TestStand Architect
(10,840 Views)
I just ran a quick test with a 'twistie' dialog VI I have that calls the Dynamic Position VIs, and it ran as an EXE just fine. Most of these VIs just do a lot of pixel math with the Position property on controls, which is supported in the run-time engine.
(9,691 Views)
Thanks Darren!
(9,691 Views)
