High-Speed Digitizers
5122 External Clock Questions
I am working on a project that requires the ext. clock (100Ms/s on a 5122) and a signal hand-off.  Signal 1 is 32MHz, and Signal 2 is 32MHz +- 100,000Hz.  If I am feeding in Signal 1, what is the minimum and maximum times I have to kill signal 1 and input Signal 2 so that the card doesn't crash.  In other words, the jitter parameters on the PXI 5122 clock.  I cannot find this information anywhere.  If I had to guess, the minimum time would be 1/105MHz = 9.5ns and the max would be 1/30MHz = 33.3ns.  The 30MHz and 105MHz comes from the PXI 5122 data sheet.
Also, if the hand-off were made smoothly withing the jitter specification times, would the clock crash due to the change in frequency between the 2 signals?
Thank you for your time,
Austin McElroy
(6,739 Views)
*I have posted the answer on all 3 of the forums that you queried, but please continue the thread here, in the appropriate section:*
Good morning Austin,
Thanks for contacting National Instruments with your issue, we'll try our best to solve it for you as quickly and efficiently as possible.
I'm going to have to contact R&D about this specification.  There are some that might get us close, such as the fact that the PLL Reference Frequency has to be accurate to +/-50 ppm (page 14 of (http://digital.ni.com/manuals.nsf/websearch/5D8BAB258130779686256FA800691AAA)) and that the sample clock delay range is 1 sample clock period (Page 13), that I could postulate on, but I'd rather get the definitive answer.
One point of helpful clarification would be whether you're using the external clock for the reference clock or sample-clock timebase.
I will let you know as soon as I hear anything from R&D.
Sincerely,
Minh Tran
Applications Engineering
(6,727 Views)
Good afternoon Austin,
Just got work back from R&D and will pass it on to you.
This is not a supported feature and as such we don't have a specification for it. However, if you're going to do it, remember the PLL needs to settle too (the timing would need to be calculated empirically). Otherwise, the sampling frequency won't be exactly what the external clock is (since it is still settling). The smaller the change in frequency the faster the PLL will settle. If you make large jumps between frequencies, the clock may become unlocked (however if you make small jumps it will probably be fine). The max size of the jump can change in the future and may even vary board to board, so give yourself plenty of head room.
Best of luck with your project.
Sincerely,
Minh Tran
(6,716 Views)
Thank you for your responses, it is much appriciated.
(6,712 Views)
