High-Speed Digitizers
Any way of making 5112 work using LabVIEW RT
The 5122 and 5124 digitizers are supported using LabVIEW RT, I am trying to make the 5112 work but it is not seen by MAX and I just found a document on the NI site that says RT is not supported.
Does anyone know of a work around (hack) to the INI files to allow MAX to recognize and work with the 5112?
Randy
(6,042 Views)
Hi Randy,
Currently we are not aware of any hacks or workarounds that will allow the 5112 to be supported in Real Time.
Best Regards,
Evan R.
http://www.ni.com/support
(6,030 Views)
