High-Speed Digitizers
Application does not install from CD but does from memory stick
I have created an installer from the Labview program and it works when I install from a USB memeory stick, but when I create the CDs the setup program gives an error "cannot create temporary file" and aborts.  Has anybody had the same problem and can suggest a solution?
(6,470 Views)
Hi Kent,
I hope you are doing well today! Do you have admin access on this computer? Also, do you run the setup file directly from the CD? You should try copying the contents of the CD onto the computer and then run setup.
Message Edited by Adnan Z on 02-08-2007 04:39 PM
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(6,455 Views)
