High-Speed Digitizers
Can I re-initiate a session once it is done ? PCI-5122
I'm developing a multi-record, multi-channel acquisition using a PCI-5122 board and Labview 7.1. I'm just Initializing, Configuring Vertical & Horizontal, setting triggers, and then use niScope Initiate Acquisition. Once I fetch all my data, I want to re-initiate the acquisition without CLosing the Session, is this possible ?.. got any examples ?..
Thanks.
Jesus.
(5,992 Views)
All you need to do is intiate the acquisition again using niScope Intiate Acquisition, then fetch. If you want to do this repetitively, put the initiate and fetches in a loop.
(5,990 Views)
