High-Speed Digitizers
Can I use NI-Scope 2.6 under LabVIEW 6.1
Hi all,
it would be very nice if somebody could answer the following question:
We have the NI PCI-5122 High-Speed Digitizer with NI-Scope 2.6 currently running under LaBVIEW 7.1. Now I have to install the digitizer in another system PC which is running LabVIEW 6.1.
Can I operate the digitizer with NI-Scope 2.6 under LabVIEW 6.1? Do I loose functionality or performance if I use the digitizer under LabVIEW 6.1?
Thank you for your help,
beam
(6,194 Views)
Hey Beam,
The requirements for NI-SCOPE are as follows:
LabVIEW 6.1 (or later)
NI-DAQ 7.1 (or later)
NI-VISA 3.0.1 (or later)
IVI Compliance Package 2.1 (or later)
NI 5122, NI 5102, NI 5112, NI 5620, NI 5621, NI 5911
NI-SCOPE is an IVI-class driver that is independent of the Programming Interface (i.e. LabVIEW, CVI, C++, etc.). You will not loose any performance or functionality from a driver standpoint by going to LabVIEW 6.1. (of course, you will lose the newer features of LabVIEW)
Good luck and thank you for choosing National Instruments!
Sincerely,
Gavin Goodrich
(6,188 Views)
