High-Speed Digitizers
Can Someone give me the file "VXI Send Message.vi"
I'm trying to use Tektronix CDS 73a-453 in a VXI Module. But to run the basic VIs for it provided by the manufacturer, I need the following four files.
VXI Send Message.vi
VXI Receive Message.vi
Open VXI Instrument.vi
Close VXI Instrument.vi
If you have these VIs in your version of LabVIEW, then please give me. Thanks a lot.
My e-mail ID is rajan_giri@hotmail.com
(6,963 Views)
Have you installed NI-VXI on your machine? You can download it here. I could send you the VIs, but without the driver (NI-VXI) installed, the VIs won't do you much good, because they will try to reference the driver. Let me know if you run into problems downloading the driver.
-Logan S.
(6,956 Views)
This question has been answered here:
VXItools
Use NI products on Linux? Come join the NI Linux Users Community
(6,945 Views)
