High-Speed Digitizers
Can't Find IVI Engine 1.83 On NI Web Site
I'm developing an application for a test system that uses the IVI Engine 1.83. I can't find this version on the NI web site. Any ideas where I can find it?
Thanks in advance
(6,982 Views)
You can find the IVI Engine 1.83 on http://www.ni.com/ivi/ivi_prod.htm.
This version of IVI Engine is not compliant with the latest IVI specifications. NI has released the IVI Compliance Package (http://digital.ni.com/softlib.nsf/websearch/6A09FEF37D6AFC2786256DBA005B2796?opendocument&node=132060_US)which is based on and is compliant with the latest version of the instrument programming specifications defined by the IVI Foundation.
Vesna
(6,982 Views)
Thanks!
dks
(6,982 Views)
